Custom 48 Whilly’s 4 seater buggy
Cobalt
Gainesville GA
Posting for a friend.
Rock Buggy For Sale
This totally custom Buggy is titled as a '48 Willy's Jeep.(Title included)
This is a totally custom four seater with racing seats and front and rear harnesses. This buggy gets great fuel mileage and has extreme turning options with front and rear steer. Locking hubs and lockers make this a nearly unstoppable vehicle for any terrain imaginable. This rig has been kept clear of mud and sand while I expect it would do amazing in any terrain with its exceptional power, lightweight and extremely versatile suspension and steering options.
If you're looking for an Extreme Custom Buggy that will take you anywhere you may want to go and most likely further than you had imagined this may be the vehicle of choice for you.
Motor Aluminum
2004 LS1
Headers/3" exhaust all the way back
Z-06 intake turned backwards into cab for clean air suction
Custom tuned to run on 93 octane gasoline
K/N Air Filter
Deep/rear some oil pan
Large Front mounted aluminum radiator with custom Thermostat controlled 2-speed electric fan integrated into the computer.
Shorty headers to 3" Magnaflow exhaust
Transmission Aluminum
Custom built turbo 400 transmission with 4L80 internals.
High volume oil pan.
Aluminum transmission oil cooler.
Stak 1:1/3:1/5.5:1 Transfer Case Billet aluminum
Stak 3 speed transfer case Low5.44/Midrange 3.0/High1:1. Billet Aluminum
Suspension
Fox 2 x 16 coil over triple coil shocks on all four corners w/ remote reservoirs
options for 2x4" air bumps on all four corners.
Single triangulated Four linked Front and rear.
2.63" ballistic joints
Limiting Straps
Rockwell Axles Powder Coated Black
2.5 ton Rockwells Full Width custom built with mohawks on the bottom/Detroit lockers in the rear/welded in the front/steering front and rear/iWilwood Disc brakes on all four wheels and rear mounted pinion brakes.
Double ended steering rams mounted on both axles.
Full Hydraulic Howe pumps/Reservoir and Double Ended Rams w/ Heavy Duty Hoses
Chromoly axle shafts in rear axle.
Warn locking hubs/Front Axle
Custom H1 Wheels Powder Coated Blue
Custom hummer H1 wheels with double bead lock and custom HDPE internal locking ring.
Tires
Super swamper 47 inch LTB
Winch
Warn 16.5 TI 12 Volt
Battery
Yellow top deep cycle
Power shut off's/1 Keyed/1 Switched
Fuel-cell Aluminum RCI
15 gallon custom fuel-cell with Corvette fuel filter/High pressure fuel pump
Roll cage
1 3/4" DOM tubing
Links Powder Coated blue
Lowers 2" 1/2" wall
Uppers 2" 1/4" wall
Custum Aluminum Dash with blue lit auto meter gauges.
Many double activated switches mounted in console.
Quick release steering wheel with suicide Knob
Custom Rear Steer lockable control handle.
Electric actuated front and rear brake locks
Floor mounted manual brake locks for parking/Cutting brakes.
PRP Racing Seats with four point harnesses.
Rear mounted 2" receiver hitch.
Willys hood and grill are Powder Coated Blue/Plain aluminum panels all the way around with Aluminum drop tailgate.
Lexan windshield and ceiling Optional
Extra wires for optional radio/CB/speakers
-Headlights/turn signals/rock lights/brake lights all custom
-Custom aluminum lockable console and tool boxes/Cooler.
Aluminum Floor.
-125" Wheelbase
704-776-1941
-Price $40,000 OBO/possible trade for Utility Side x Side plus Cash
Rock Buggy For Sale
Motor Aluminum
2004 LS1
K/N Air Filter
Suspension
Limiting Straps
Tires
Winch
Battery
Roll cage
1 3/4" DOM tubing
Lowers 2" 1/2" wall
Uppers 2" 1/4" wall
Aluminum Floor.
-125" Wheelbase
704-776-1941
Sorry. Location is Monroe NC
