Which Link Material?
I priced Branik, before Kelly found the source hook up he has now. They were a bit higher. We didn't machine the wrench fitting on the links.
I haven't figured out that need. What do you need it for? I only use one wrench on the thread locking nut. I dont think I'm missing anything, and my links are staying tighter than a virgin choir boy in a Catholic church.
The links already on my buggy were also not keyed for a wrench. But they do have this cool two line groove on the end that is left hand thread so you always know which end is the lefty end. Very cool! I think Kelly needs to incorporate that, once he saw them on mine, he was like "DAMN, I should do that"
PM'ing you the Branik qoute I got in Dec.
Cole said:
I will be going with 2" 7075 with 1 1/4 heims all the way around
That is what I have on the lowers with 3/4's on the uppers.
One thing that I find interesting from TC is that all of my heims are Right Hand. All of them. Never asked why.....
Easy way to keep them from loosening up.
My rig is setup the same way, all are RH threads. When Dan redid the uppers he changed them to LH at one end.
its only nice to have rh/lh during testing and setup. after that its a hindrance. with TC knowing the formula, no reason to have something easy to tune. My link grow in length when I beat teh fawk out of the rig. I jam the nuts as tight as I can, have even used a 3' wrench on them (on the 1.25's) and when I smash down on a link like on primos, you can bet that withing a couple more hours of riding, I will be readjusting pinion angle and jamming back. if you have all RH its only 1 spare and if your link starts to walk, it doenst change length, it just walks to the end of one rod end and to the body of th eother. if there isn't much thread showing, **** it, you'll never have it come out.
Anyone tack the jam nuts? Obviously not with AL links but with regualr DOM ones.
Figured that was the case. I have no body showing on any of my heims. Material/Jam/Head....makes it easy for sure.
I talked to Stan for a while in Hannibal about that. He suggested doing it that way, said there would be not worry's about them becoming loose. He said that is what they did on all of their rigs.
yep, I regret having lefts. it was nice when I was finalizing my pinion angle and wheelbase and all other manner of ****, but then its a bitch after that. to change a right only system, you pull a link and run it in/out. or just have mockup links laying there.
Yep, I have L/H and R/H threads and one of my uppers jam nuts came loose and the whole axle shifted to the side about 4 inches. Luckily I caught it before it fell out. :eek:
Next time I would do all R/H threads. thumb.gif
Thats why I have heard of tacking the jams, but thanks to this thread I think I will go all right hand when/if I link my rig.....never thought of it, my tie rod is all RH beacause the only chevy TREs you get at the parts store LH are like 5 inches long and have a hole for a steering stabilizer.
I might do that on my uppers but my lowers are aluminum. :mad:
Is that enough material once you cut the threads? That only leaves .375 wall thickness around the threads. i am planning on running 1-1/4 JJ on mine and atleast 2.250 links.
2.00 7075 Alum 36" long wieghs 11.417 LBS
2.250 7075 Alum 36" long wieghs 14.449 LBS
If you use the 2.250 for all eight links thats 25LBS heavier. Is this worth it? I have never run or seen anyone run the Alum with 1-1/4 personally so you guys tell me.
Man I have no idea. If I need to run 2.250 I will. Whatever I run it better hold up because it's going to get the beating of a life time.
I use 1-1/4" J.J.'s with 2" Aluminum link material. No problems so far. I think there is plenty of meat left around the threads.
Thanks that's what I was looking for thumb.gif. Sounds like the "Rock Midget" runs the same set-up on his, maybe he will grace us with his wisdom/opinion :flipoff1: :afro:.
On a side note, Ken at KORE built these for me and he did not have any concerns either. I think he has done quite a few sets for others as well.
