Breaking Birfields every wheelin trip!! Need help!!
Just checked them out I'll get them next week.Thats the next weekest link strips the end of the birfield out it said .Did not know that.
What happens is they usually crack the gear which lets the gear open up and lets the splines slip damaging them in the process....
If they are bobby's chromo 30 splines to retain the warrantee on them you must run his hub gears....
Yup, he is very clear on this when you buy them. I've gotten about 5 sets of them from him and he told me each and every time. Cause as you stated thats the week spot and its known.
If you break them or the axles they are covered. But if your stock hub gear breaks an takes the spline off the birf, that is not covered unless it is our hub greas then it would be covered.
If you break them or the axles they are covered. But if your stock hub gear breaks an takes the spline off the birf, that is not covered unless it is our hub gears then it would be covered.
fixxed for ya Bobby or Tina...
I sure wish you made Birfs for my D30:booo:... Your customer service is 1 of a kind awesome!!:awesomework:
this is the most true statment on the board.
I don't and can't run any of bobby's stuff due to my setup.
BUT.... I am going to be sporting some new bobby long shifter knobs soon.
Support local vendors!!!!!!!:beer:
axle swap BL and hub gears
K2Blazen you should post up what happend to your housing when you birf blew!!! I wanna see the carnage!!:awesomework::beer:
Ended up getting a new housing ,and hub gears ....one thing after a another
after this I will be confident in my front axle which was the weekest thing on my rig ,$920 later ouch! hungover zombie at work the 2 pic, Still trying to make it North this weekend with now problems.If not Eds $hits done do me a favor if I don't make it gets some good footage .Built2beat not bought to fluant.....
30 splinerz,detriot locker,5 trusion bolt,529,tg armor.
Whats the liklyhood of the axle tube being bent enough to cause the axle to be unable to spin without binding. I know the yota axle tubes bend. But im noy realy a toyota guy is this posable or likly?
Don't cool the axle with water. You want the axle to cool as slowly as possible. When you use water to cool the axle you cause it to shrink at a very rapid rate. Weld in a criss-cross pattern with short stitch welds and let it air cool for a few minutes between each weld.
I use the one 2" weld one beer method.
cool
I wont, thanks for the .02 cents just started welding on it..
No wonder you can out drink most:haha:... you have a **** load of weld's on that rig of yours.:haha:
blingin
axle polished ready for paint!I know my axle is not bent just built2beat!
Its also a good idea to weld a small section and wrap it in a welding blanket and let it cool slower/stronger = more beers inbetween welds.
Its also a good idea to weld a small section and wrap it in a welding blanket and let it cool slower/stronger = "more beers" inbetween welds.
You gotta talk in Mike speak...
wich is....
"Its also a good idea to weld a small section and wrap it in a welding blanket and let it cool slower/stronger = more "WHISKEY N COKE" in between welds.":haha: :fawkdancesmiley:
