bobbedrunner99
Member
- Joined
- Jun 19, 2017
- Messages
- 10
- Reaction score
- 0
Been having a weird issue with my hydro assist since setting it up. Steering works great turning to the left, but when trying to turn it right....Binds up and doesn't want to steer. It only does this turning right, will turn left all day long.
I did take the lines off and worked the steering on just the box and it worked fine, put the lines and ram back on it worked correctly and turned right just fine for a few days and then started the binding up issue again.
Also rebuilt the pump before I put it on. I assume it also pretty well bled. Just at a loss of what my issue could be
PSC Ram
Trail Gear Pump
Trail Gear Reservoir
Drilled and Tapped the box myself.
PSC Ram
Trail Gear Pump
