05+ superduty disc brakes
Re: Re: 05+ superduty disc brakes
wizzo said:
Yours are stock 05+ F250/350 dual piston calipers. They are big girls.
I'm pretty sure, the lugnut kit uses the typical chevy single piston caliper that most everyone uses for 14b disc brake kits these days.
The lugnut kit uses an early 2000s F-250 caliper and rotor, it's just a little smaller, not much tho. It's supposed to clear 16s, but I can't confirm. It's what I have currently. I had to re-drill the rotors and the spacer that goes behind the rotors. If it would come drilled, it would be a decent kit
Sent from my Pixel 3 using Tapatalk
That's right! I stand corrected. 28 lb weight difference from his post.
If it did that would have my interest and what I was hoping for. Unfortunately that's not the case.
Metchosin joe said:
Has any one found an 8x6.5 rotor that works with the stock ford calipers?
Try a 06 Dmax rear on the front.
