slravenel
wizzo said:Branik has nice stuff for sure. Are you going to use the 6 piston wilwood calipers? Or what calipers are you looking at? Reason why I ask is, I have 4 piston willwoods on all 4 corners, if I did it again, I would got with the 6 piston calipers.
I have a theory that the 4 pistons are really only any good on a thin 3/8 thick rotor. When you start getting into the wider, stock width rotors the caliper will flex since the body of the caliper is spaced out so much at that point. I cant really confirm that to be the cause with real data...but ive only seen them flex when they are on wide rotors, and when they are on wide rotors they almost always flex. ??? ???
