Juan_Hong_Loe
That's dumb
Cole said:You find me someone around Gibsonville NC that will lengthen my axle and I will have it done.
I told you I would do it. :afro:
Juan_Hong_Loe said:Cole said:You find me someone around Gibsonville NC that will lengthen my axle and I will have it done.
So you gonna drive to NC get my axle, fix it, then drive it back up there?
I mean if you want to cut into the HP go for it.
Cole said:So you gonna drive to NC get my axle, fix it, then drive it back up there?
Juan_Hong_Loe said:Naw mang you got it all wrong...You gonna drive up there I'll ride with you, bring it back, fix it, then ride with you back up there to deliver it. 8)
Matt O. said:It is ghetto as **** but what about moving it over to one side for angle and running a wheel spacer on the other side to get the track width right? Yeah that is gay now that I typed it. Jim is a long way away which also sucks. Can you run a bigger joint for better angle or a CV shaft?
lay said:i guess everybody who is building a buggy on here right know is havn the same problem ........fawkin drive shafts :flipper:
mine isnt an angle problem, its clearing the links problem
rock mafia said:Who wants to buy a cool ass narrowed dana 60?
P said:Who was actually originally running this axle ? I know Matt got it from Nolen, then Cole got it from Matt.... WTF on this thing man laughing1
Bones said:Maybe I missed, but retubing it is too spendy of an option right now?
Marty said:Just UPS it to truck supply and let daniel fix it ???On a serious note http://solidaxle.com/ProductCart/pc/viewPrd.asp?idcategory=18&idproduct=78 it can be delievered right to Jims door, then you can peel the **** out.
74_Chevota said:I will buy that shat real cheap.![]()
B Gillespie said:If you have a high pinion driver drop housing, you will only need to add tube to one side.
-<>---- cut the long side down to make the new short side giving you this: -<>-
Then cut the short side off and retube it to make a new long side ----<>-
Swap the gears out and you're done in a day.
