Re: S10 build sas aka by popular demand the rasta truck
Cut edges of the tube bent it in so I don't have to use adapters anyone ever run it like this ? About to weld it all up and do the other end
Might want to plug weld the bung to the flats since its a loose fit if you're going to do that
You know they make square bungs right?
Re: Re: S10 build sas aka by popular demand the rasta truck
You're relying on only this weld holding the bung.
Think about the vertical and horizontal movement from the shank not making contact with the inside of the link. That's why I mentioned plug welding also
I'm goin to drill through and run a bolt
Free is going to get you stranded out on a trail with an axle broke clean out from under it.
Well that sounds cheaper than a $3 bung
drill thru the bung and the rod end? How ya gonna get it out when you need to replace it?
The damn heim shank probably isn't long enough to thread all the way down the insert. thumb.gif
Think of all the money saved on jam nuts though!
I know that I have made some questionable fabrication decisions in the past that my friends have called me on. Looking back I'm glad they did as it would have ruined everyones day on the trail.
417chevy- You are obviously willing to put the work in. That's why these guys are willing to give you advice. I would start listening.
I stopped giving a fawk about this thread a long time ago. I just read it for laughs now. It's about like watching someone glue popsicle sticks together.
Then don't post
Tacoma JD, your such a hater! When he gets this S10 Rollin, you will be like, dam! I should have kept my pie hoe shut! :flipoff1:
Is this going to be ready for Alaska off road warrior season 2?
What is that
X2. How awesome would it be to see the S10 pullin the red Barron out of a ditch? Hahaha
I'd pay to see that ****!
