81 toyota project
Looks like a D44. Puts some cromos in it and its good to go. I mean, he did make a Yota axle last this long.:corn:
Well heres what ill be working with...
Front:
93 dodge 60
5.13 gears
narrowed to 64.5 wms
6lug
35 spline inner and outters w/spicer life joints
35 spline warn locking hubs
35 spline ARB
ballistic fab diff cover
BTF steering arms
high angle toy60 flange
Rear:
D60
5.13 gears welded
narrowed to 61.5 wms
6lug
toyo 60 hybrid axle kit
retains toyota brakes
35 spline 1541h shafts
BTF truss
Rear axle needs some work, front will stay pretty much the same
more pics to come
Im starting with the rear, got springperches, trac bar mount, shock tabs and truss cut off. Got everyting all cleaned up. Took off the drum brakes and will be putting on my disk brakes. BTF truss will be put back on after pinion angle is set and more truss added on out to the end of the axle. Also shaved have a little bit of the bottom. I really want to redo my rear suspension but this seems to work for me so it will probably stay the same.
time for a small update...
front axle in and ready, rear axle all ready but not in.
Ive been working on some other little things like...
-building dual propane tank mounts cause one tank just doesnt cut it
-adding tabs around the roof line for a roof panel
-adding tabs and bracket to hold things on around the rig in place of zipties
-stripped the interior and back half and sanded and painted to make it all fancy again.
heres a few pics
it moves and is almost ready to wheel:cheer: Just need to install front bumps and shorten front dline...
that thing is SICK!!! i live in shores and have a 79 yota about to put on a trail gear 5" lift. after i get er all done we'll have to go out wheelin. i dont know to many trails out here. but i am definitly jealous of that thing. nice work
FOR THE MILLIONTH TIME this rig is badass! :awesomework:
and im gonna go out on a limb here and say your finally linking the frt?:corn:
yep, links, full hydro and stonger knuckles for the front. If everything goes good I hope to have it all together for septembers Best in the West race...
Right on! That thing is big time:cool: Can't wait to see it go back together:awesomework:
..."KOS"...:awesomework::;
just a couple update pics...
truss plates and winch plate
All the steering goodies
solid knuckles w artec arms
the orbital mount will go right on the firewall
found this when i pulled out the inner axle
frontend shot from today... front tubework almost done, axle truss, link tabs, links done and shocks mouted up, just need to get the steering on there and put the frontend back together and ill be ready for a test run
