91 truggy build
lizard lips
Las Vegas NV
I've been building another truck after I decided a toyota 4 cylinder is stupid and has no juice. Here's some pics of it. It'll have a cpi 4.3, a JET TH350 dual 23 spline marlin cases with a 4.7 in the rear case. Marlin 23 spline inputs with 10* rotated adapter and tripple drilled flanges
After I finished the spring hanger. Waiting on my front 60
Started collecting parts for it
4.3 with air compressor out of the ac compressor
Put some 38x15 boggers on it and moved it to my new house.
I have the motor in but no pics yet. It was cold and dark.
Here's the cases
Kinda prepped under the hood, with the gm master cylinder
Here's some more updated pic.
Motor mounts in
The motor still is going to be moved back about 3-4"
Front spring hanger
Box and steering
i like your work!:awesomework: saw your thread on pbb.. are you gonna have a buildup for pig's truggy too? that was my favorite toyota.
tubing material. 1.75" DOM .250" wall, and 1.5" DOM .250 wall.
Radiator I'm using. For a nova or chevy II
28" wide, 18.5" tall and 2" thick at the radiator and 3" thick at the tanks
Some updates for you all. Here's some pics of the rear tubework
I'll have the rear axle sitting about where it is when I'm done
Under the motor
Sky's offset shackles
Waiting on the 60
to put in
1/4 ellips buckets.
Cut the rear axle off. Swapping it with my other axle on my other truck. Need to build the truss and weld the link tabs on.
u might want to put a skid plate on that oil pan and also the tranny pan, I have several dents in my oil pan, the tranny pan is fun to weld a skid plate too lol. I had to pull the tranny pan off to weld a skid to it :redneck: .
no updates yet. I got some more parts again. 14 bolt disc conversion parts,
some air bumps, they were converted from air shocks. 5" travel
and some bling high steer arms
with the th350 tranny plus adapter and the duals how far back is the back t-case shifter. ive been debating on going with duals im running th350 and adapter to 23 spline case and that already sits back far.
well I don't have the shifters in yet. But they will be kind of far back. I might also be getting a driveline disconnect. You can't do it with a bench seat. unless you modify the shifter. I know marlin has a product like that or you can make your own. I throw the shifters on a see if I can get a pic.
