91 truggy build
Well the crossmember didnt' show up. Should be here tomorrow or today for the shifter pics
Some updates over the weekend. Put the discs on the 14 bolt. Going to start The link truss today. They clear 15" wheels. I can't remember what kit it is but I'm using ruff stuff bent brackets.
mounted the 60 all the way. Mounted some 38's. Still haven't gotten the single wheel hubs.
Got some work done yesterday.
lower link crossmember and mounts I might have to modify it a little to clear the driveshaft.
Front range rotated crossmember
Everything mostly in place. The cases might go a little higher.
I don't run gas with this welder. I'm getting a new welder soon. Just haven't got around to it. I can convert my welder to use gas but I haven't yet.
Some more work done over the weekend.
Upper frame link mounts. STill going to beef them up a little more.
Lower link crossmember in.
Started the axle lower link brackets.
Got the lokar shifter in after modifying it a little. And the 2nd case shifter. I still need to get a shifter for the crawl box
a few updates. Finishing up the rear suspension. The rest of my joints should be here tomorrow. Then I'm working on the wiring. Still need to finish bracing the rear truss and caping the front and rear of it.
more pics of the truss. still going to brace the middle of it
and my front links. 4130 chromo 7/8 heims, going to be replaced with some new ballistic joints
uppers 1.5" .250 wall
lowers 1.5" .250 wall sleeved with 1.75 .120
some more updates. Took the toy cases off. Sold the dual case adapter, rear case and crossmember. Getting an adapter from OTT to put a dana 300 behind the first case. Just waiting on parts again.
Some updates finally. I can finally move around again after having knee surgery. Got the adapter I still need a c clip for the output shaft. Hopefully I'll have it all in this week.
And the dana 300
The gears are stock in the toy case. Everything will probably be cryoed. The dana 300 with be upgraded with 32 spline outputs twin stocks and clocked up.
sweat. this is pretty cool. im thinkin bout back halfin my wheeler. tube is so much cooler than a bed. plus im thinkin bout linkin the rear at the end of summer, or maybe fall, or maybe, no i wanna get some wheelin in this year. next year i will link it.
