Air Shock Tech
  • Thread starter Thread starter lowbudgetjunk
  • Start date Start date
Timjus, with the coilovers the back end looked like it was welded to the chassis. Might throw the air shocks on the back and see how you like that.
Re: Re: Air Shock Tech
Timjus said:
did some spring swapping today and tested it again.
i think i need to get some coilovers to my self too or my nephew will have too much advantage over my air pogos.
rancho rs9000x coilover testing 2
Some preload on the right springs and getting the valving right would make big changes from the video.
It's obvious rebound is too stiff. More spring preload and/or lighter rebound valving will help.
rear is still kind of stiff but it feel much better with coils than it did with airs. currently has 125/125 14" coils in rear and 200/175 14" in front. valving in thease ranchos is not so easy it only has the 9 position knob and body is welded shut.
did calculate corner weights from coil sag and got front 800lbs and rear 560lbs
