Dain Bramage
my pinion bearing is going out. actually, its probably completely gone right now. the pinion is so loose right now that when i come to a stop, i can feel it wobbling. i talked to a guy today who told me that when the pinion bearing goes, usually the gears are toast too, especialy if the oil is silver. then, i talked to another guy who said that the gears can usually be re-used if you catch it in time. both guys i know pretty well, and i feel like i can trust their advice. i called trail-gear (i bought the diff set up from them, 4.88 and a detroit), i want to see if they will cover parts and labor since it should still be under warranty. if i want it warrantied, tho, it will probably take a little bit longer, unless they tell me to go get done whatever needs doing and send them the bill, which i cant see happening. i talked to a guy today who told me that when the pinion bearing goes, usually the gears are toast too, especialy if the oil is silver. then, i talked to another guy who said that the gears can usually be re-used if you catch it in time. i dont think i caught it in time, crash tightened the pinion nut 2-3 weeks ago, after i pulled my driveline to do a u-joint and found gear oil puddled up in the flange. whats everyones thoughts on the condition of the gears? i would like to get it done in time for the turkey day snow run.
