rooinater
i'm putting the heavy weight .2 gram airsoft bb's in my 39.5 iroks. i'll see how they do. but i really haven't heard anything bad about running the bb's only good reviews.
Im' resurrecting this thread, cus i love it! :fawkdancesmiley:
And because i think it's failed me, or i've failed it, I put in 6oz of airsoft pellets in my 32x11.5x15 BFG's and they wobble like a SOB! :booo: I know i'm 2 ounces short of the reccomended amount, but damn! It's awful!.
Just venting... BB's don't like BFG's. :fawkdancesmiley::haha:
Although they work perfect in 36 Iroks and 39.5 Iroks at 70mph+. :eeek:
I might add more this coming weekend and see if it cures it. :corn:
well since truckers invented this system of balancing for retreads way back in the day cause retreads are very hard to balance id suspect the tires themselves?
i have some ol school BFGs on my hotrod mustang and those tire have come apart inside before...
have you looked inside for any seperation or flat spots on the tires?
im certain its not the BBs issue as they work. unless you might need 2 oz more the chart was developed for a reason.
curious to find out?
i run air soft pellets in mine, use the innovative balancing chart..
works good as long as your tires aren't fawked.
also, remember if htey are biased, it takes a couple miles befor they warm up and become "round" again..
I used the balance chart but had 2oz less in each tire (didnt buy a 3rd box of pellets, normally 2 is enough) I just cant imagine that 2oz is a deal breaker, but i am def. going to try maybe 4oz. more, just to see.
Hopefully the tires aren't messed up, they rode fine on the other wheels when they were balanced with regular wheel weights. :eeek:
The real solution to this problem is 35" MTR Kevlar's...![]()
Do you have wheel spacers? I know someone who did all kinds of messing around with his wheels thinking they weren't balanced or had bad spots only to find out his spacers were the issue.
I just installed AllPro spacers when i was messing around with stuff... :eeek:
I would pull them off and I bet the death wobble goes away. :awesomework:
I bet it would too, cus i wouldn't have wheels on the truck! :redneck:
I need the spacers for the wheels to clear the brake caliper, its because the tacoma apparently needs special offset wheels vs. the standard black crawler wheels i got.So unless i go back to the old wheels.... they have to stay on there, plus, if spacers are the problem, why are my friend's AllPro spacers not shaking, and the thousands of others that run spacers as well... :eeek:
I've ran spacers on two other occasions thru the life of my old truck and never had a shaking issue caused by them. I sure hope it's not the spacers after the trouble i had to go thru and the smashed finger. :haha:
I know its a pain but I would pull them and put them back on. It has been an issue with the FJ's too. I think it is the hub centric design. Did it shake before you installed the spacers?
I've had several different tires on my rig, and the Iroks (36" bias) gave me the death wobble, I've tried everything, tow in, tow out, changed my castor, everything, the BB's worked till I hit a pothole, then I'd have to pull over, come to a stop and then start again, I finally removed the BB's from the front and got them balanced, it helped, but didn't get rid of it all together.
Are those the original bfg's from when you bought it? I seem to recall balance issues with at least 1 of the tires. I just rotated it 90 degrees and was able to balance it with lead. It never was absolutely perfect but close enough. They were cupping a bit IIRC.
