Roy_Hobbs
muddinmetal said:3.8 IS THE WAY TO GO
The 2 times a trip toy can't hit 60 mph will not outweigh the 25 times you use the lower 1st gear
And what you gear you run the hardest/best in?
Roy_Hobbs said:And what you gear you run the hardest/best in?
June dog said:Forgot to put that there 42" irocks
And have a solid 400 hp
Roy_Hobbs said:ok heres one. Just guessin on tires and rpm, but will be close. 44" and 6000rpm
tanner top speed: 1st- 18.6 mph
2nd- 30.7 mph
3rd- 47 mph
my possible set up: 1st- 17.2 mph
2nd- 28.5 mph
3rd- 43.4 mph
Id say that pretty close to same. But was 2nd gear in tanner buggy fast enough to get it done (id say it was). thats what im looking for, speeds that people like when they gotta put out or get out. If you know these speeds you dont have to mimic every aspect of someone elses rig to get what they got. You can make adjustments based off what you have to work with to achieve same result as other rig.
krackem said:Mine is second gear with a 22re front case in high(2.28) and rear case in low (4.70) and 5.29 in the axles on 37s and don't have a tach so don't know rpm there's a chart some where but I'm to lazy to look for it :****:
June dog said:With the stall it flashes to 3200 maybe alittle more. If that's figured in low range those speeds seem way off to me there's no way it will run almost 35 in first low range. Something there don't seem right ???
kturner said:Moonlight Bounty Hill 2014 new years day This is 4 to 1 (doubler in low side) 4.10 axle ratio and 300hp and second gear on the tranny
RockinDfarms said:If you are going to have 500+ hp i would go with 3.0 & 4.56 or 3.8 & 3.73. We went from 4.56 to 4.10 in ANGER MANAGEMENT(Nick Cooper) with a 3.8 because he was running out of gear.it seemed to help a little but, now he wishes we would of used 3.73. I would try to keep your final ratio somewhere in 13 to 15:1 area.
NTIDWELL said:How do you figure mph I got crawl # First setup is t400 2.43 672 6800 rpm SLOW
1st 34.47
2nd 24.16
3rd 16.32
This one is t400 3.1 490 7000 rpm. Bad mo'fo
1st 37.67
2nd 22.48
3rd 15.19
That was the second time I had the buggy out and so far I love it.Last rig before this one I had a doubler with 4 to 1 low and 5.13 gears and it was too slow at times . Didn't have the wheel speed sometimes . Had stock engine also. The new one I think has the best of both worlds , has some wheel speed and can still crawl.Roy_Hobbs said:That looks pretty good. Would you change anything if you could? im having trouble now deciding 3.0 or 3.8. Would really like the lomax 205 i think. 3.8 would have to be atlas.
KTurner
Mph Crawl Ratio
1st 18 41.3
2nd 30 25
3rd 46 16.4
