Boonie Buster
Stuck on a Curb
So the trucky is getting a makeover... inside and out...There are a few things that will get done after the Naches Trip, but most of it has to be done by early/mid june
To Do List BEFORE Naches:
-Build HP Dana 44, cut down to desired length, trying to figure out what STOCK axle to use on the long side....and make it not too wide...
-Install 5.13s front and rear, plus replace rear wheel bearing and seals.
-Setup steering a little more proper...
-Assemble Dual case setup; Chevy NP203/Ford NP205 with NWF doubler.
-Build Custom Crossmember(s) for the dual cases and possible an extension forward to cover the trans. pan for a belly skid
-Build new D-lines, both SINGLE piece YOKED d-lines:haha: no more two-piece rear and CVed front shafts...
-Install blue top optima and new main battery wires.
-If i get time, I will attach my new fangdangle winch pulling aparatus.:awesomework:
-replace worn rubber fuel lines.
To Do List if i get extra time before Naches(will do it after i get back regardless):
-Build cage (internal:fawkdancesmiley: ); Attach seats, button down speaker box.
-Build rear tube bumper
-Build Front Tube bumper w/ stinger
-Figure out rocker slider things...
-Rewire switches, Air compressor, etc.
-Dual Battery setup. (one more blue top)
-Mount winching aparatus:cheer:
Pics to come!!!
Pics to come!!!
