breaking toyota hub studs...
I don't know how hard you wheel your rig, but the key to the hub studs staying around is partly what chopshop said, double-check them after you've run a short while... The other is make DAMN sure the locating dowel pin holes aren't wallowed out, causing a loose locating dowel, and DON't assume one dowel is ok, cuz it's NOT; I fought this problem for abit, and after going to a different wheel hub altogether (one that the dowels were tight), my problems ended....:awesomework:
spooled in the front with 38's, and a v8. yep my shits weak...
:fawkdancesmiley:
:awesomework:
just fawkin witcha:awesomework: when they do finally break get some APR's and more dowels,
then it's onto the next weak link in the toy axle:D
don't worry i am a turd polisher to:redneck::haha:
wish i had the money for 60's:booo:
