Cooling issues with new system
Reason I think the pump I havemay be ok is one the motor starts to get hot and water is circulating constantly with thermostat open you can tell the water is moving to fast as both hoses - inlet and outlet are damn near the same temp. It is moving through the radiator faster than it can cool it.
Greg - what kind of pump are you running? edit - nevermind I see Stewart
With my rear radiator, I can't get all the air out while backing up on a hill. I have to pull the upper rad hose on the motor, and fill the engine first. Then crank it up and let it circulate while topping it off.
