Bigshowdawg
- Joined
- Sep 25, 2010
- Messages
- 154
Why run 2" shafts when you have neck them down to 40 spline why not get 300m regular rockwell axles and mill them down?
Bigshowdawg said:Why run 2" shafts when you have neck them down to 40 spline why not get 300m regular rockwell axles and mill them down?
ryannuttz said:So what is the advantage to running their shafts? Are ppl. breaking the cross/body of the ctms?
Cole said:I think it has a lot to do with the metal Spidertrax uses and there Heat and treat Process. Same goes for CTM 300m shafts.
redneckengineered said:You guys that are pushing the limits of axle strength have you considered the fact that once you spend a million dollars on bombproof axles you're going to start breaking t-cases and transmissions? I don't know about you but I'd much rather deal with a broken shaft or u-joint on the trail that probably has a lifetime warranty or I can at least replace much cheaper/easier than blowing up an Atlas. You bust an Atlas or trans on the trail and you're going to have your thumb up your ass for the next few weeks unless you live next to AA. Also, get your wallet out that ain't a cheap break.
redneckengineered said:At what point are you building a monster truck? :****:
Blase said:Those parts will cause the rig to become big and heavy thus making them break also! DO you think a monster truck would break if TC drove it up cable?
I like watching the southern wheeling videos but I don't see anything holding up long too the abuse those boys throw down!!
YOUNG said:A C103 axle with the 2 inch Ouversons is lighter than a 14 bolt front like everyone is running. The drop box is also lighter than a atlas.
B Gillespie said:What is the point when you live in Vernon?
patooyee said:That's what Gerstner says but I have some doubts. I recently weighed a bare front rock housing with just lower link mounts and knuckles on it and it came in at 217 lbs. That's no chunk or anything. I haven't weighed the 14-bolts or d80's that I have in the shop. I will on Mon. But just from lifting them I would say that they are much less than the rockwell without gears in them.
Think about it. Virtually every component in a C103 (except the pinion) is bigger and stronger than a 14-bolt. It just doesn't make sense that you can put rockwell outers on it to magically make it lighter than doing the same to a 14-bolt.
J. J.
YOUNG said:Not a stock 14 bolt, but one of the 14's that have been sleeved(over the stock tubes) like Coleworks runs. The tubes on those are like 4-5"
