Dana 60 6.17 gear strength?
Turtle Bite
Ellensburg, WA
What kind of luck are people having with the higher Dana 60 gear ratios? I was considering either 5.86 or 6.17, but I dont want to break ring and pinions. I have 35 spline yukons and drive flanges on order, I would prefer to keep the weak point the shafts or joints.
whats your setup and size of tire?
I have a toyota, 39.5 tires in the rocks and 44tsls in the snow, vortec 4.3, th350, dual t-cases, (both stock ratio but 23 spline/ chromo output).
I realize I probably wont break anything as I am set up know but after the axle upgrade I may swap in some more HP. I like the lower gears for the crawl ratio, but I dont want to worry about getting new gears for the next 5 years or so.
if its not a trailer queen you should be alright but if it were me I would run 5.38s and never think about it.
I would not go lower than 5.38s anything lower than that and you will be running a spicer gear which are great quality but dont seem to hold up as well as an aftermarket gear to off road abuse.
I was wondering too. you would think the 6.17 ratio would have less contact area than a higer ratio set. (4.56 or 5.13)
As long as your rig isnt a heavy pig you should be alright. Hell I run 7:17s and to date(3.5 years) havent broke one yet. Mauler runs 6:17s and dont think he broke a set yet either. Hopefully he will chime in tho.
I believe Mauler has had them crack though and just caught them in time. Seems to be the gist of what he posted on the subject a while back.
I quoted myself from the other thread cuz I'm too lazy to type:rolleyes:
"Just a heads up......I cracked two sets of 6.17 R/Ps. One was subsatnially cracked and ready to fail(front) and the rear was just starting to crack at the root of the ring teeth.They were Dana/spicer gears.
I warrantied both sets (Thank you Randy's R/P )and carry a full R/P spare in the tow rig.I NEED to check my front again to make sure the teeth aren't trying to fall off....I'd bet they are cracked at the root at least.
My rig is WAY smaller with alot less horse power(3000# & ~325 horse) so I can't see them holding up in yers any better.My plan is to go 5.38 at the diff and a "baby" stack/3oo 4:1 and take some of the load off the diffs. "
My buggy is apart and under the knife now and I will be going through both diffs/axles...I fully expect the front R/P to be cracked......I just checked the rear a couple months ago and it "may" still be OK
we competed with a buddy who ran a old cruiser with hydraulic suspension and leavesprings and 44 swampers back in the arca days. It was bushing 5300lbs witha 389 stroker and he never broke a 7:17 r/p. And he won multilple events with the set up.
I think mine will be ok....I do not plan to run the OM or any real crazy stuff....I will know on new years day .....I plan to lean on the new setup hard and see what it will handle:cool:
Well ****, your right there Nuzzmaster. I run the 7:17s in my 60s and have never broken them yet in 3.5 years of wheelin. I must not be as hardcore as I thought.:booo: :booo:
It's a matter of torque. Yes torque not horse power.:flipoff:
If you don't have low gears in front of the R&P and or you don't have torque at the power plant the weaker gears will last longer. Even if you do have the torque there must be some resistance in order to do damage. That's why big tires tend to always break gears/ axles. Small tires can do it too if you wad them up....
wasn't this also when you were running water in your tires? Do you think the extra weight in the tires had a large part in the ring gear breaking? I would be interested to see the gears now since you have not been running water...
