1badlscrawler
- Joined
- May 16, 2013
- Messages
- 45
- Reaction score
- 0
Badass front and rear axles but got a ? do u have to run special cut gears or just run regular 14 bolt gears?
Not sure what you are asking? if its wiring then its a pacfab ready to run that we had them swap the drive by wire throttle body out for a cable one, brand new cut down harness and reflashed computer. It made 410 with the factory manifolds and I will be building long tube headers for it so 425ish.Technician said:Is the 6.0 gonna run on the open circuit?![]()
These are turned down for the shave kits but yes Nitro 5.38's the front will run on the coast side but no worries.1badlscrawler said:Badass front and rear axles but got a ? do u have to run special cut gears or just run regular 14 bolt gears?
Thanks.frittsx4 said:Nice, and yes I'm still entertained :****:
1badlscrawler said:Are they standard rotation or reverse rotation gears? Sorry for all the ?s but mite be building a 14 bolt front just wasnt sure on the r&p.
It will have O2 sensors.Technician said:If it runs open loop you it will bypass the O2 sensor.
Monster in a box kit with red clutches, kevlar bands, reverse manual valve body, shift kit, upgraded sprag, upgrade drums, chromo 32 spline output shaft, upgraded pump and extra capacity pan. I think thats it, I hate auto trans and wanted to go nv4500 but its not my buggy and this trans should hold up and launch preety good with the 2200 stall we got.Technician said:Any mods to the tranny?
BBRC Fall Crawl at gore will probably be the last big out of town run for us this year, have to see how bad I wad my buggy up and how the budget looks.Technician said:Y'all need to come down to Chocco in November. Big toyota event.
