Finally....Da new rig..
I got the whole front of the car fully wired up to the electrical center...
More panels going on....
I got the heater installed and holes popped thru the firewall and heater hoses ran. Its pretty tight but everything fits...
I got the electrical center finalized and added mounts for the circuit breakers that will be used for the high output stuff.
I got the dome light and light bar installed and wired.
I got the center console installed and the vent ran from the heater to the outlets....
Everything starts with a mess with me,lol...
So it took a bit of work and was certainly in a pretty confined area but I got the electrical center done. I did forget one circuit that I will add in this weekend but its pretty much done in here. I always build and then add fiuses per each system to test and verify.....
So I got a bunch of stuff put into the car--center console/dash/switch pod and shifter. The shifter took a bit of work. I first found the backup lamp switch brackets on the shifter housing was binding up the shift cable. Once I got that fixed up it was a matter of figuring out the needed process to get the shifter into place--should be easier next time.
With those items in I was able to start throwing voltage and was happy with the interior lighting...
So I got the sub box all done(wire pass thru installed) and installed and the center console storage and the wiring all hooked up.
I got the air system all plumed and finished. I ran the pump and found a damn leak. Well low and behold both the arb solenoids were leaking. I suspect they had been leaking for some time as my old york seemed to come on too often. Got them both replaced and the system fully functions nicely.
Got both seats and belts installed. Taking shape...
Everything looks great with the exception of the front clip, just when I thought you moved up in the world.:fawkdancesmiley:
I got the roof put on and more parts--its really looking like something with every step. So the time had come to fire it off. I threw some gas in it, fuel pump did its 2 second prime and nothing-grrrrrr. I could not hear the pump run while cranking and the check engine lamp was not coming on. So I hooked up the scanner and no crank rpm-hmmmm...
So I did a quick basic check and found no voltage(12v) at the crank or cam sensor. I ran those 2 sensors off one fuse. So now I had to dig into the harness and I don't know how the hell I did it but somehow I got one power circuit mis-directed(ecm was supposed to have 2 fused circuits one B+_ and IGN B+). Well I had 3 circuits and the cam/crank simply wired togther-oooffffff... Can't believe I did it but I fixed that up. Now onto the ses lamp the ecm ground command was there and pulled the dash top--well I totally spaced the fact it being led and got the circuit backwards--fixed that and ses lamp works.
So I cranked it over and it spit/popped. Well when I had the motor out prior to painting well I had spaced off making sure the distributor was correctly indexed. Well guess what it was off and the damn crank pulley has 2 marks. Well I got it corrected and the damn thing fired right off...
