How much does your rig weigh?
2684 yota drive train full tank of propane
Sorry sap, I hate to break it to you but that buggy weighs a lot more than that. I'll have to look through my notes when I get home, and see if I can find the numbers.
Unless you've changed the axles out for some toyotas.
Re: Re: How much does your rig weigh?
shrek tits said:
Bitchin hood! Did you do the work? Any more pic's
Chris at Mars fab biult it there is a biuld thread on here
You must be thinking of the blue buggy. I think it was around 3100 lbs.
2710 lbs wet. (1230 kg)
4.3/TH350/Dana20/Toyota axles/Leafs/36" Irok/ heavy ass Chevy G30 steering box
2781 lbs.
Fj axles 22rt/aw4/dana300. Most cage is .120 wall parts are .188 wall mainly lower frame rail and under belly. Full wet weight 12 gal of fuel also.
Looks like going tons is 1000 extra pounds. Over 1/3 of a stock yota. I never would have thought it was that much. :o
Wondering if the ton Toyotas are running stock axles or any weight saving mods?
I'm 2620 ready to go.
Part of that is likely the upsize of wheels/tires too.
