ain'tstuckjustresting
RIP Mister 12/5/12
joe,
pos says: There is no such thing as air in my lines since the flow of fluid and it being a closed loop system the only place the air can go is out the res even if the res is mounted 2' below the system. He said that the cooler that i have is not the best but a heat sink cooler is the worst, almost zero heat disapation cause all it is is just a tube. He told me to get a stacked core cooler. he also said my ram is on the small side for a double ended ram only being a 2" bore with a 1.25" rod and 8" stoke it is causing the bump to go into bypass mode. he also said the mods to the last pump where what killed it so quick but not the only thing that killed it. He said i could get away with my res and napa pump if i had a 2.5" ram. Being that my orbital is 2.9 revs lock to lock that increases that by 60% making it slow. So if i want faster steering i will need a bigger orbital.
I dont really know who to trust. I see people running all these brands of parts and systems but why is it that they dont agree?
:fu1:
