gubni
www.lugnut4x4.com
I have a pretty awesome CJ that I have been wheeling for the last few years.
blacksheep10 said:$55/hr shop rate x however long it takes
patooyee said:Why would reworks be any more per hour? Its all the same labor, just more of it for a rework. Just because its annoying having to fix someone else's mistakes?
fl-krawler said:That is a pretty cheap labor rate. While I charge a flat fee for a lot of the things I do, custom work is $80/hr.. Reworks are $100/hr because you usually have to spend a considerable amount of time either removing old parts, or building something new that will work with the old, and still fix the problem.
InDaShop said:Jimmys4x4 is $55/hour I believe. And I am having a go fast car built now, and am paying in that range at a very well known shop in Arizona. FYI this car was built for $50/hr @ Penhall in SoCal.
InDaShop said:whats your budget? is it several K, or 10, or 20, or 30? And how much can you do yourself tools/skill wise, vs. hiring out. or do you hire out because of the time constraints?
You certainly cant argue with RedneckEngineered on just buying a new chassis from WideOpenDesign, or even dropping all parts on Woodlees door step. You'll definately get more value back that way.
FullMetalFabworks said:"Why would reworks be any more per hour? Its all the same labor, just more of it for a rework. Just because its annoying having to fix someone else's mistakes?"
I found this to be rather interesting as well . Wish I could charge different labor rates depending on how much fun the project is, $50/hr to weld , $75/hr to sand for the first hour and then it jumps to $100/hr after that when I am tired of it, and then $200/hr to pack any bearings. I like the sounds of that
jlowry said:As far as increasing your rate to work on "reworks"??????????? We all agree that they take more time and so it's going to cost more money but seriously?? That statement couldn't have helped business>
JohnG said:I think I understand why he has the different labor rates for quoting the job. He is giving a quoted price. Say it normally takes an hour to put in a brake pedal, and two hours to put on four coilovers. But, due to the re-build, he quotes at a higher labor rate. The brake pedal takes longer because the bracket has no place to attach, so he has to build something. The coilover brackets are too close together, now he has to cut it off, reposition, and replace. I did not get the idea he was charging more per minute actually worked, but rather using a higher labor rate during the quote process, to take into account unforseen problems.
patooyee said:So the total quoted time would be the same, but on a re-work job the rate would be higher to account for any extra time beyond the quoted amount?
Great questions you have. I was wondering the same things. I am in the fabrication business and typically your shop rate includes all overhead and consumables. That is why its called "shop rate" and not "personal rate." We employ around 60 people at a coded vessel shop and our rate is $65/hr. Must be a really big business charging $80-100 an hour.patooyee said:Why would reworks be any more per hour? Its all the same labor, just more of it for a rework. Just because its annoying having to fix someone else's mistakes?
FullMetalFabworks said:InDaShop, which AZ company is building you a car? Campbell Ent, TTF? Its cool if you don't want to say, just was curious and kind of hoping it might be EZ. Love that guys work and would like to see more of his rigs out wheeling.
On the Penhall car, was that "$50/hr" quote from Ben or directly from Penhall? I don't know for sure but I'd venture to say that they wouldn't build the same car for just anyone at that rate. I think that was a marketing move/ special rate (and a smart one IMHO) to build the most expensive ULTRA4 car to date for the generally likable and jolly Aussie with the funny accent that the cameras love to interview. He also happens to have a pretty respectable race history and they know that means good exposure for them in a new market and he'd still be campaigning it as a very capable 4wd Class1 in pure desert races as well.
