I think this would be the shizzz (Steering Quickener)....
  • Start date Start date
P said:
NO ****??? :eek: You guys totally miss the point... Its all good I wouldnt expect anything less.
I got the point, you are cheap and want faster steering :flipoff1: Sounds like a snake oil fix is all. I hope it works for you because your steering needs help! ;D
Mathmatics son, it will work.. its a mini gearbox, whatever input goes in one side comes out the other side multiplied...
If I turn the wheel 1/2 turn , the orbital sees 1 full rotation. My steering works good, just takes an excessive amount of input. Now it takes 1/2 the amount of input since there is a gear box in front of the orbital.. kinda like the gear set in your Tcase only backwards instead of reducing, Im amplifing
Ill sacrifice a snake and spread its guts around the orbital if that will make you feel better. :flipoff1:
Lebron was the cat with the CRS ? Fabrication or whatever buggy, it was red and black on rockwells and very clean. He had his two boys with him most the day too :afro: Ill see if I can find a pic to refresh yo memories. I like to meet new peeps !!!!
I think this would be pretty damn cool as well. I mean the only drawback would be traveling at speeds but mine is never driven on the road at all. Installation would be quite simple as well.
Ok I know who you are talking about now. That thing looked good. I didn't even realize it was on Rockwells until someone pointed it out.
I drove it a bit ON road last night... the front drivers tire was basically flat ( stupid plugs leak down.. ) and I had a rear really low as well. Steering is WAAAAAAAAAAAAAAAAAAAAAAY better, a little under 3.5 lock to lock, the small inputs are what I really liked though its more arm work to steer, feels like a real vehicle or truck but agian I had some flat tire issues and Im welded front and rear on pavement so heavy steering is obvious.
Looking forward to wheeling it this weekend and seeing "real world" how I like it, I already feel it was worth the 140 shipped with the adapters to make install a breeze though.
( EDIT: I havent driven it because of the Tcase being out , its back in , I did some linkage work and it feels way better shifting wise as well, and Im 32spl front and rear too !! :afro: ) Also in doing that upgrade I replaced the front output seal which had been slowly dripping since installed, one less drip to watch
