It wasn't purdy enuff for me!
SO I found a 'deal' on some Pitbulls. Got the rock rings off the tires today, start the mount/dismount process tomorrow.
Got the Rockers mounted up, goddamn that is a big tire! Good on the road and what little I've wheeled so far. Rubs when making a hard left on the drivers springs.
The cig lighter wasn't working, so I pulled the whole dash apart to find out that I only needed to pull four screws to figure out that it just wasn't plugged in! :mad: Then I fixed my cb cable that the gf destroyed awhile ago and now I have cb capabilities again.
Thanks for the beers rus:awesomework:
Thank you! I should probably paint that thing before it rusts up. I need to get harnesses/cage padding sooner rather than later too, my head took a beating driving around in the snow!:redneck:
I wonder if phill still has some of that cage padding he scored from setina. Once you get your harnesses you should be good:awesomework: Give me a shout if you need the tabs welded on for those
Hans. Just now seen this. I have a ton of really nice cage padding. Help yourself to however much you need. :awesomework:
MY shits got issues...also just saw the truck I could've gotten instead of this one. Wish I wouldn't of seen that.:booo:
what kind of issues? My **** has issues also.. I dont know an vehicle that is not new on the lot that does not have issues.
Like he said, theres always issues with one thing or another. Life... wheeling... etc. would be to easy if there was none. Keep at it :awesomework:
I was just having a whinge. I'm sure my issues are minor compared to some, but for me they're a major challenge.
Issues: 1) Pitman arm cornholes spring when flexed.
2) Tires contact body when flexing.
3) Leak in power steering, somewhere.
4) Brakes suck.
5) No back-up/rock lights.
6) Squeaking from rollcage driving me ****ing insane on highway! :pissed:
Solutions: 1) Sky 3/4" less drop pitman arm. ?
2) Move front axle forward, cut off more fenders. ?
3) Find leak, fix leak.
4) Replace old doubled up line, with new extended steel line in rear. ???
5) Figure out how to wire up lights I have. ?
6) Remove seats (:mad:) cut out around cage legs, seal holes and lay down more peal and seal. Also finish painting cage.
If anyone has any suggestions, I'm open to hear them. :awesomework:
If the cage is sqweaking around the areas it goes through the body swing it down and I can open those up without having to remove the seats. Give me a call and I will help you get the cage sqweak free:awesomework: Although it might be sqweaking on the roof aswell as it was tight against it to get the most headroom possible.
