Low Budget rear engine, 37"s
35 spline spools front and rear. Seals-it axle seals in the front housing.
There are 35 spline spools available for a stock small bearing third member. They are thin in the spline area and may crack and fail if pushed hard enough. I used that style spool in stock third members until the third cracked. Luckily found it before it spit the pinion out on the ground. I am still using the same spools in big bearing nodular thirds with thicker bearing races for the time being. They are holding up fine with low horsepower.
I suggest getting nodular thirds from Strange, Yukon etc it is a little $ up front but will save the headache later. The stock third WILL crack or completely fail around the pinion.
I was hoping too but Dirt Riot canceled the races that were at Choccolocco and Gray Rock. So looks like trailriding it is. No extra $$ for traveling.
awesome info! Did you just flip the stock 3rds? did that cause the failure at all?
The entire axle housings were flipped. Stock thirds fail / crack when run in the original setup and flipped the castings are just weak. The third member didn't crack at the spool. It cracked around the pinion. Not related to running the spool.
How much trouble did you have passing tech since the chassis isn't built out of Dom? I ask because I had thought about building a similar rig
I was never asked about materials. In hindsight I would use dom for the rocker/subframe and ABC pillars starring to see a couple of dents.
I really like your rig! Do you think the drivetrain would have been okay if you did not race it? Did you do anything special to oil the bearings in the third members?
Thanks for the complement. I think the original engine failed because I was a used engine and I didn't know any history on it. The 4.3 in it now has a standard 2wd oil pan and pickup and has no oil pressure issues climbing..just not enough hp.
No special oil in the axles, they are just over filled so the pinion bearing get bathed in oil and not overheat.
One of the cheap rock auto unit bearing did finally fail on my last trip to Hawk Pride. I think having water in the front tires and bumping ledges was too much for it.
TBITOY probably nailed it being a thin spindle due to the bushing. I will try to get it out of the trailer and check it out asap and will report what is found
Pics from a year ago.
I spent the summer swapping out the 4.3 for a 5.3 LS. The 4.3 was working fine I just wanted more power. The new engine actually fit in the chassis without cutting but there was not enough room left for the radiator. So it the chassis got a little trim.
Test fitting was sketchy using a high lift to check clearances.. I swapped the truck oil pan for a pan from a Trailblazer SS. It is a factory front sump pan that will keep the pickup submerged with the nose uphill being rear engine. Lucky for me the new pan has a built in burrito / hot pocket cooker. :eat:
If you are not mocking up exhaust pool noodle yall are missing out.
Chassis finished up, engine in, air intake and exhaust done. E bay truck cold air intake and GTO headers flipped and swapped to the opposite sides. Turbo style mufflers.
The air filter is close to the header so I built an airbox to protect the filter and get some cooler air into the engine. The airbox seals to the hood and a scoop directs air inside.
The wiring from before worked fine but not thought out enough when installed. This time around it was too hot to ride so I spent a couple of weeks doing wiring. I am happy with the results no extra connections than needed, all the circuits are color matching to the factory GM / LS harness. This will make trouble shooting the wiring a ton easier if needed since it matches the factory schematic. Fuses on all the signal wires to the relays and ECM.
I like having the ECM control the 2 fan speeds as well, one less thing for me to worry about.
