My Angryfab buggy "ISSUES"
Picked up the chassis today!
THE ANGLE ON THAT FORK IS MAKING ME SWEAT! I can just picture that chain sliding off! Keep us updated man this thing is gonna look nice!
There's a hole the chain is thru
No telling how many chassis/buggy that forklift has loaded. Including mine.
Got late, didn't want to start on rear links so I stuck res. up there. Is that to close to pump it's pretty much right above it.
Don't think these lower coilover mount is going to work, have to cut off the piece it bolts to, and mount them down low on side of the truss.
I have mine mounting similar on my SBC. I think the theory is directly above helps eliminate starvation or whatever.
As long as you can route the feed line to the pump with no issues I'd rock it.
And maybe think about some protection for the resi. Mine sticks up similar and I knocked off the vent elbow when I rolled.
Thanks, I may slide it down a little lower.
Get it as low as possible, your engine cage is so flat compared to most it may be difficult.
Edit, lower but still the highest point. :dblthumb:
Rear links, as it sits right now, 22" belly and 123" wheel base
Shortened the wheelbase to 119, and moved upper links in at the axle. Now I have to make longer coilover mounts, so tank doesn't hit the links at full bump
That fuel tank hanging out of the cage right above your axle would make me nervous.
I'm assuming your going to add a little tube and some beefy bumps?
redneckengineered said:
Got a thread on yours? That looks like a WOD chassis in your avatar. I dig it.
Thanks, I bought a wod bare chassis in Jan/16 built it and was riding by sept 16. but no build Thread I'm terrible at taking pics and documenting ****.
It had 60's front and rear I replaced them this winter with bubbas front 40spl 14 bolt and built a 14 bolt rear. you just sent me a set of mark Williams shafts for it.
Gonna and bump stops for sure, not sure about any more tube
Sitting at full bump, about 3/4" between fuel cell and uppers. Rear resi mounted
