Thank youftoy516 said:I Love your rig man.
Keep up the hard work, its going to turn out nice.
Thanksdrycreekjeep said:Looking great!!
Haha yep. We had to notch the rail to clear drain plug, but didn't think to check filter. When I pull the motor, I will notch it further down for the filterj-mox said:How do you change the oil filter? Remove motor mounts and jack it up?
Looking good!
Rear is 18" 150lb on bottom and 16" 125lb on topEddyj said:New springs will settle a little.
What are your spring length and rates?
Rig looks good.
Everyday I find something else lolpoolman said:Looks good man, it's a task to get everything together only to find what you missed!![]()
I was looking at that yesterday. I think I will try and make something that deflects it around the sides of the cellBeerj said:Coming along nicely. I just want to suggest maybe adding something to deflect the hot air from your radiator away from the fuel cell. Even if it's just a piece of aluminum spaced 1/2 to 1" away from the fuel cell. Hot gas sucks.
