Newbies Post Up Here - Rig Specs & Info Thread
  • Start date Start date
Here's my 2001 Tj HD dana44 HP front Dana 60 rear, 12" fox 2.0 airs on all four corners. Stock 4.0 nv3550 with 231/300 doubler setting on 2
39.5-13.50-16.5 iroks.
Sent from my DROID RAZR HD using Tapatalk
Been reading for awhile but I figured I'd regester. I'm from western oklahoma, most of the wheeling we do is local in canyons and we make 3-4 trips a year to clayton down in southeast part of the state.
I got a cj7 with amc 360/chevy tbi injection 727 dana 300/4:1 gears, dana 60/70 4:56, four link on coil springs for now, 118inch wheelbase. Nothing fancy but it goes.
I'm from NE Florida
my rig is a 00 Jeep cherokee limited
HP 60 front with 5.38's, 35 spline 4340 outers, yukon hubs, spooled, WFO truss. rear is a 14bolt with grizzly locker, 5.38's, trussed, and disk brakes.
Hydro assist steering with 1.5x25 dom steering and track bar.
14" ORI struts up front and 16" ORI's in rear. 3 link front, 4 link rear 113" WB
37" MTR-k
NP231/dana 300 doubler
and a bunch of other misc work. converted to ax15, high clearence bumpers/sliders/ and belly, Hybrid cage with internal support , yada yada yada
its my DD/family wheeler and i just got it mobile. just made a 1200 mile round trip with a week of rock crawling in the middle.
Chris from Swannanoa nc.
Cj theme 2 seater, built ls, th400, 203/205, 60 front yukon grizzly yukon hubs usa made chromos, 14 rear detroit, both trussed.
17" bighorn coilovers, old as dirt 42" tsl's on steel beadlocks.
Id post pics but tapatalk shuts down when I try.
BUCKEYE PERFORMANCE INC. 828-779-2242.
Not sure I am "new" here, but been lurking for a while enjoying this great community...been on P4x4 for more ages...so these two forums do it for me...
Trucks:
Daily Driver 2015 G500, bone stock
Desert camping rig for the family: 1998 Land Rover Discovery 2 door with 4.6 V8i, manual, 33s, King 2.5" with reservoirs, OME springs, Warn XP, cage, drawers, extra fuel, custom bumpers, rack, fridge, and an accompanying trailer with pop up tent
Dual Sport rig: 1991 Land Rover Defender 110, custom everything, 35s, OME springs, Fox 2.0 with reservoirs, beadlocks, cage, Warn M8274-50, 4.2 V8i, Manual, doubler, Rovota front axle high pinion 30 spline Chromo, S60 rear axle with 35 spline Chromo, 9 seater!
Comp rig (still WIP): 1983 Land Rover Defender 110 pick-up, RWs, 54s and 42s, Stazworks, dual ORIs per corner, LQ4 with Z06 internals and tune, NV4500 with goodies, Atlas Race Case 3.8, High Angle Drivelines F/R, Wheel disc brakes, triple winched, custom exo cage, PRP seats, Corbeau harnesses, CBR radiator, LED everything
Hardline value ( no butthurt!)
I don't know if this will work or not. It probably will end up derailed.
Alright see if we can do this.
Step 1: post up a picture and description of your ride.
Step 2: the "all knowing" members of hardline will value your ride.
Step 3: no butthurt
Re: Hardline value ( no butthurt!)
This should go smooth..
Ftoy chassis
01 5.3 cam n springs fresh rebuild needs tune PSI harness and ecm (AN fittings with ss fuel lines, 17 gal rci fuel cell)
Th350 manual vb fresh rebuild,art carr shaifter
Ford np205 fresh rebuild, jb twin stick
SD dana 60 (all parts new)
Welded, yukon 5.38,bored unit bearings,ecgs 35 spline cromos, solid diff cove4,barnes 4 link brackets, 1.25 lowers 7/8 uppers
14b rear
Yukon 5.38, disc. Brakes, solid diff cover,barnes 4 link brackes, 1.25 lowers/7/8 uppers
Fox 2.5 shox
14" front 16" rear
TG DE ram steering kit
And so on, damn near everything is new
Hardline value (NO BUTTHURT!)
I'm not sure if this will work. It will probably be derailed within 3 post, but let's see if we can do this.
Have you ever wondered what your rig is worth? Or how much it would take to buy a buggy/truck?
Step 1: post up a picture and description of your rig
Step 2: the "all knowing" hardline will give you a realistic value
Step 3: no butthurt
Re: Hardline value (NO BUTTHURT!)
My bad didn't notice I was merged.
I was merged against my will. :flipoff1:
So let me get this straight? You think when people first post up their super awesome rig on this site for the first time, and we tell them it's worth $47.50 that will be a good ideal? Ok let's do this! :woot:
rednecklights said:
Someone will end up punched in the nose
kmcminn said:
There would be less hurt feelings if we ranked each others wives and girlfriends. Our 4wd's are nothing to be joking about.
I know it's going to be awesome :****:
