Newbies Post Up Here - Rig Specs & Info Thread
  • Start date Start date
Re: Hardline value (NO BUTTHURT!)
This is a double post John G merged this with "newbies post up a pic" thread. :dunno:
Randys Rock rods chassis
5 sticks of .188 wall Dom rest .120 dom
Powder coated
Ls1 comp cam with head work
Built Th350
Atlas 3.0 2 speed
Cucv 1 tons
Yukon axles/joints
Welded front
Fox 16 coilovers
4 inch fox bumps
1 1/4 heims
1350 .250 wall shafts front/rear
Dual steering pumps (front steer only)
Wet sounds bar for the coon tunes!! :JRich:
Here's my beast. I know its worth way more than you initially think, cause you cant see the value unless in person. It'll go anywhere. I wont go into details cause I dont want to sound elite. It'll follow the buggys everywhere... :****:
5BrothersFabrication said:
Specs in sig. Edit: add onboard air, big sub, amp, LED rock lights, and XRC8 winch.
Don't forget the tools-free hub removal!
85 CJ
5.3
Auto
Atlas 4.3
HP60 front Chromos and Longfield Joints, 5.38, Detroit
14Bolt- Detroit
14"ORI's
43SX on Raceline
Lowrance HDS5
Premier Welder
Onboard Air
and all the other odds and ends
HP44 RCV Yukon Grizzly locker 5:13 gears 3 link
Ford 8.8 Yukon Ultimate 88 kit welded
roll cage
seats
some sweet 35" BFG KM2 tars
soon to get stretched and 4 linked in the rear
not the fanciest or anything but it works well.
FlatlandFSJ said:
Merged again :spin: All I gotta say, is that is a super clean CJ dude.
Thanks Man, I did a clean up and repaint in the spring.
I don't think I ever posted a pic and put up my specs, I guess I got confused with the merger of the threads. I'm not looking to sell or really care whats its worth at this point.
Re: Hardline value ( no butthurt!)
hjpcummins said:
This should go smooth..
Ftoy chassis
01 5.3 cam n springs fresh rebuild needs tune PSI harness and ecm (AN fittings with ss fuel lines, 17 gal rci fuel cell)
Th350 manual vb fresh rebuild,art carr shaifter
Ford np205 fresh rebuild, jb twin stick
SD dana 60 (all parts new)
Welded, yukon 5.38,bored unit bearings,ecgs 35 spline cromos, solid diff cove4,barnes 4 link brackets, 1.25 lowers 7/8 uppers
14b rear
Yukon 5.38, disc. Brakes, solid diff cover,barnes 4 link brackes, 1.25 lowers/7/8 uppers
Fox 2.5 shox
14" front 16" rear
TG DE ram steering kit
And so on, damn near everything is new
Everyone scared to start? I'll go first. Good list of Parts but definitely hurts value not being assembled completely. I would say "come pick it all up" price would be between $5700 and $6500.
Powder coated
Built Th350
Atlas 3.0 2 speed
Cucv 1 tons
Yukon axles/joints
Welded front
Fox 16 coilovers
4 inch fox bumps
1 1/4 heims
I would give my left nut! $37000
How do we know if someone wants a half assed evaluation of their junk or if they are just posting up their newb pic?
LOOKING FOR "hardline value" skully
I'll go that way you guys can beat me up also.
**** chassis that got reworked by rocfun
Cheapest drive train:
Old school 350 on pane
4 speed
205 w big outputs
All 1410 joints
Welded rockwels
Mrw wheels
42 %50 tsl
New seats
18 res coil overs fox and saw
Basically the cheapest "bouncer"
97 tj 4.0, automatic, np231, 8.8 welded, d30hp aussie, .120/.188dom cage, 8k chicago winch, 2" body lift, explorer wheels, r85 buckshot tires, fiberglass hood, no front fender or inner fenders, 2 racing seats, 4pt harnesses, rear seat with 3seatbelts, dd and wheeler stock shafts with only sway bars removed
