Bones
That Guy
[raises hand] SO DO I! [/raises hand]MUCHADO said:hey P,
J Rich has 2 ears and 2 inches of shaft, will that work?
DOH!
MUCHADO said:hey P,
yer kinkyCheapJ7 said:Nope.. no ears but a little longer shaft....
But hey, I've got a 9 inch in my rear, so what the hell do I kno...![]()
Matt O. said:He needs the ears, that is the point of the shaft. Ears will become they 1350 yoke
I am so effin lost as well. Do a new thread, step by step with nudity please.Matt O. said:I am again confused. Checking out of this one, good luck with your dshaft P![]()
P said:Yea dood... and the roadmaster's and action packer ! laughing1
to some extent, but its seeing 1/4 the strain. He has 4.1 ratio, so its reduced after the shaft meaning way smaller parts upstream are okayJohn Galbreath Jr. said:Something a couple of posts back got me thinking. If a shaft has been broken or run a long time, would it make a good drive shaft, verses a new shaft. I always think about my shafts after I have twisted the splines, and then run them the other direction, if they are as strong as new. I don't think they could be. If the shaft has been broken, it has had a huge shock put to the entire shaft. I think it would be best to buy a new 44" long side shaft and cut it down.
internal clip style. there is a cross joint that has internals on one cap and externals on the other cap. or see if the axle shaft joint will go in your yoke on tcase to ubolt it in.lay said:alright P i made my driveshaft today like we talked about , but i tried to figure out wtf matt was talking about, the axle shafts ears are 1350, but i had a regular 1350 ujoint and the axle shaft ears are way to close to run a regular 1350 joint so matt what type of joint are you running at your axle end just wondering my shaft is already done![]()
