Pathy Front end Redo
Here are a few more pictures of the bumper. Should get it finished up next week sometime. Then I'll be in the process of moving, so probably not a lot will get done for a while.
[/QUOTE]
Finally got my rear bumper finished.
Broke a coil spring (4x4parts 3" lift spring), so I had to replace them. Had a set of stock XJ's laying around so I tried them. Quite a bit too short. My rearend sits about 1" low and they springs fall out with the rear end flexed just a bit.
So I order some RE 4.5" XJ springs. Little lighter rate then the 4x4parts springs and a bit longer. Hopefully they work.
New springs came in. Here is a comparison of several springs.
Left to Right: RE 1310 4.5" XJ front lift spring, Cut RE 1310, Automotive Customizers 3" Pathfinder lift spring (used and bent), and a cut stock XJ spring.
Sits much more level now.
