I forgot about that--- Possable axle wrap....
Or just increased angle from droop. Silly leaf springs with rear shackle setup these toys have. :haha: :haha: :haha:
its binding at a rest. and what is confusing to me is that my driveline angel doesnt look that bad at all
yes i will take pics tomarrow in the daylight and get it posted up for u tomarrow night to look at and then go from there
got to have the dough to dual case it but that too will soon be in the works trust me, so where did u get ur billit shims at? and with ur shims do u have a problem with ur hysteer arms hitting the top of the spring when u stuff ur tires?
If you're ever going to drive this on the street don't use shims. Do it right.
I have never had a steel one fail. it cost a ton of money/time to rotatae knuckles if your not super handy. I understand why folks dont like shims. but if used properly (bolted to spring with full pin engaged in pad) they pose no threat. Ill bet I have installed shims on more vehicles than you have owned with no problems.:awesomework: you can even weld them to the perches on toyotas, they have steel perches not cast into the third.:beer:
not starting a debate, just sounds like he aint got the dough to it the BEST way.
Which driveshaft flanges are you using? The IFS front flange? or an early flange? Might be as simple as building a new d-shaft. Knuckle rotating is a bitch and its what you need to do if you don't want it to steer like a slot car on crack on the road.
I get the steel shims at RIGHT WAY SPRING in tacoma. about 20 bucks.
4 degree will rub a little when flexed, no biggy. 6s will rub alot and be noticeble with the histeer kit.:beer:
How much does it really cost to do a budget cut & turn?
A couple bucks in grinding wheels, some wire and shielding gas? I guess you gotta buy some spring perches (assuming you're not careful taking the old ones off) and an angle finder if you don't already have one. You can even relocate the fill plug for basically free and weld up the drain plug so it doesn't get buggered up anymore. Even if it costs you a six-pack to have a buddy weld up the knuckles for you, how is this expensive?
Probably still comparable to the price of new spring pins and quality shims and it will be done right.
