Project "Secret Squirrel"
skrause said:
Lemme guess, you saw Brad's and just had to have one huh. He did the same after seeing mine in action. :flipoff:
I have actually had mine for over a year but only used it for doing GM fuel line stuff....
:clappy: That thing is F'N Sweet! I can't tell you how sweet it is...if any of you have ever seen mike go HE GOs. Great Job Mike! If one thing is not complete its on to the next...:clappy:
OH and did I methion it is lookin pretty sweet right now. :D
bobbed_84_toy said:
X2! That thing is sexy lol:cheer: Tires stick out too far though. Dang wheelers:flipoff: :kissmyass:
And its still like 8" narrower than my rig :D
i touched the sammi tonight, :flipoff: lookin strait pimpin. the front winch mount/ crossmember/spring mounts are beautiful. :cool:
Ok since I am waiting on more parts I was going to push the rig over into the other stall and get mine ready for this weekend----but I couldn't :redneck:
I went and mounted the ecm---but I didn't like how it was so I threw those mounts away and re-did it. This time I liked how it turned out MUCH better :;
So then I sat down and ripped the 2.4 toyota engine harness apart--Identified all wires and curcuits and started building the harness.
I also went thru the stock sami harness that was under the hood and there aint much left now :redneck:
Now this is very roughed in for now but I plan on wiring the rig with the possability of the fenders/fenderwells no longer being there :D
You're my wiring hero.
I would probably look at both those harnesses, scratch my head a bit, give up and bring the rig to you. Guess you're good for something at least. :flipoff: :haha:
My contribution
Got Nubbies?
Nice job Mike. If you need someone to break her in my services are always available LoL:flipoff: .
MIKE you are the man.
BUNK you are the man.
PORTER YOUR services will not be needed.:flipoff:
ha ha... WIres don't scare me as I have worked on some of the most highly technical vehicles on the road--this **** is easy :flipoff:
So I am going to rework the stock samy power feeds, kill all the rh/lh fused bullcrap. I am also going to pre-plan for the possability of no more headlamp buckets (due to no sheet metal there,lol) and rewire that portion of the circuit off a relay since there is a good spot for diffent headlamps (more power means you do not wanna run circuits thru stock switch) if need be.
But my god these old sami wiring schematics suck :flipoff:
one word: fourtynine:flipoff: :flipoff:
j/k
so far its looking great mike. yet another top notch job:cool:
Well I got a couple boxes and here is something that was in one of them. We will be running rope and this was just too sexy to not put on :D
So I had a chance to start mapping out the electrical circuits. I decided to go and make a mount to hold the relays and found a place for the new fuse block...
After figuring out what all the circuits were here is whats left of the factory harness that I will be using (firewall side). There was also alot of redundent **** in this harness so it will be simplified without taking away anything...
And I went thru and figured out what all the fused circuits are in the factory fuse block. The now dead circuits will be re-routed for the new circuits to keep it clean/simple...
0 Words
