Project "Secret Squirrel"
So just putting along and getting closer to having some steering in this thing
Here is the orbitral mounted. I thought I had the complete stock sami steering shaft and I didn't--just the u-joint. So all I did was take a portion of a toy steering shaft--turned it down so it fit into the splined area of the zooks u-joint and welded it in--As a safety precauting I also notched the shaft where it went into the splined area and retained the bolt...
So the rig is now half way there to having steering.
So I drug this tuna can out and---time to get the ram mounted...
Looking closer and closer!
What orbitial and ram are you using.
I got the orbital from rockstomper.com
160NR Steering Control Valve +
Steering coupler +
Stub steering column+
Northern tools for the ram
9088408 CYLINDER 2 X 8
Today was good prgress--got to the mark I wanted to...
So I lopped off the plate that sits where the shackle will go
Here is the little gusset I made to retain the passenger inner u-bolt
And here is the front diff--the only thing left to do to the front diff fab wise is make mounts for the shocks--which will come a lil later... But the ram is now fully mounted..
Here is the ram mount on the housing---if it leaves the housing--its take a rather large chunk of the housing with it,lol...
Just a couple other pics----
