RE-ntal
Hey! I'm back with progress after a 1 month hiatus. Last I had developed some fine non-functonable rear shock mounts and suffred a case of fab burnout. But now I'm back with progress.
So the rear shock mounts needed to be changed due to masive shock-to-bolt interfernce. Fortunatly I was just tacking everything together so removing the old mounts was a breeze. I came up with a new design that pushes the shocks up about 2.5 inches and in a inch, I also added some speed holes so it didnt look so plain and it will go faster.
No more hiting the bolts :cheer:
Inside view of new rear brackets
Next I needed a way to make upper shock mounts. I wanted to bend a 180deg hoop and atatch the shocks to that but after holding my 180 mockup piece up for a few hours I decided I hated it. I ended up with a bent tube that spans the rear tubes, now the problem with this is the tube is 1.5" wide, and the shock with spacers is 2.5" wide. Lucky me I just got a new job where I have acess to a press break so I made...
Mmmm... me likey
So after all that I finaly got to do a final articulation test with the actual shocks, not my mockup ones to make sure everything clears before I weld it out.
Oh yeah! she fine. do welds, son.
Now on to the front. I squared up the front axle and got it all set where it needs to be. I whiped up some upper link mounts and atatched them to the axle and that funny jog I put in the frame (I said it was there for a reson :D )
I ended up angling the front link towers forward a lot, this was a problem because I wanted to do shock mounts the same as in the rear, but with the shocks to the outside and above the towers, call in aformentioned press break again and a few hours of brain teasing design and layout and I now have...
speeeeed holes :D
These should angle the shocks back about 7deg, I'm realy pleased with how they turned out. Now to figure the lower links so the pas side dosnt hit the d-line :eeek: gona be reeeeeel close. Fortunatley I posess the power to make whatever diamiter d-line I want. :D
ABOUT TIME YOU POST NEW PICS UP ! NEED NEW SKIN ON THE SUPER FIGURE 8 CAR YOU KNOW ANYBODY ?:fawkdancesmiley: :awesomework:
I ALREADY TALKED TO YOU ABOUT SKINS FOR THE F8 CAR, YOU TROGLODITE!!
:haha: :haha: :haha: :haha: :fawkdancesmiley: :kiss:
now ya just need a set of dimple dies for them speed holes.......
If you can find me a set of dimple dies that will dimple 1/4 I will be more than happy to buy them :D
Oh, and not require a 500 ton press :redneck:
One of our press brakes at work is an old Wysong that is all mechanical and runs off a "giant" flywheel/clutch set-up. Drop that badboy from the top and it would dimple 1/4":redneck: If not It'd sure be exciting:beer:
Those breaks are awsome. I've worked at a few shops with them. If you smash them in to something too hard they bind up and nothing good hapens, watched a guy bind up a 200 ton mechanical press in Yakima, whoops, :haha:
was his name E.T.:haha:
The suspension be all done and she's a roller :D
Front linkys at ride height
Twist testing to make sure it all clears. It needs a highpinion diff.
weld weld weld.
After building the shock hoops for the front, rough cutting some holes in the hood and welding everything out, I put the fake shocks on and rolled it outside for some poser shots
Tube'y front, much nicer than a frame and fenderwhells :D
Front link bracketry
I also had a lot of free time at work yesterday so I bent up a stainless batery tray and holddown
But most importantly Colin aproves.
With the 37's on it it has 19" belly clearnce, 72" to the highst point of the cage and a 106" wb
0 Words
