TacomaJD
I LIKE CHEAP STUFF.....
Hollytree suckssssss compared to Hale Mtn, and most every other park. Lol. Hale is a badass yota crawler park.
TacomaJD said:Alright, here's what we've tried/checked so far.
Main thing we do not have an answer to is the fact that it pulls plenty vacuum where the air filter mounts onto the mixer, but if you unhook the propane hose at the vaporizer that runs to the mixer, there seems to be zero vacuum pulling through that hose.
We've bypassed the filter and the solenoid in the propane supply line, both are working properly and it made no difference bypassing them.
We took the mixer and carb off of the intake, inspected everything, and put it back together with new gaskets....made no difference.
Checked every possible vacuum line, lines/hoses are in good shape with secure, sealed connections.
Took the vaporizer apart and there was a decent bit of oil in it, probably from the flop. The little sponge was totally saturated in oil, along with all the diaphragm parts. All diaphragm parts have been thoroughly cleaned and the sponge cleaned and restored....no difference.
Sprayed brake cleaner all around the intake where it mounts to the head while cranking, with no results in terms of firing. Does not appear that intake gasket would be the problem.
Take the air filter off and block off the hole with your hand and it will try to fire immediately....so that tells me there plenty of vacuum there, it's just not getting any at the propane hose that connects to the mixer.
If holding the button down on the vaporizer while cranking, it will crank and continue to run smooth and fine until throttle is decreased and it runs rather choppy at low rpm's, ultimately going dead if throttle is continuously decreased.
I still haven't had time during the day to call Buddy, but that's my next step. I'm completely frustrated with this, as I can't think of any other things that could possibly be wrong. We plan to do a compression test just for ****s and giggles to make sure there isn't an issue with piston rings. It doesn't smoke at all and this issue happened so abruptly, I don't believe there's an issue there. I don't fawking know....pisses me off. Maybe there's something wrong with the mixer? The mixer is such a simple part, it's also hard for me to think there's something wrong there, too.
TacomaJD said:It's fixed bygawd! Ordered new 225 mixer diaphragm from Buddy yesterday at 4:45pm and it was on my doorstep this morning. Installed and sumbitch crunk right up and idled like a champ.
Comparing the old one and the new one (which is made out of different, hopefully better material), best I can gather is the old one was just sort of "stretched out" and flimsy. If there's a pin hole in it, you need a microscope to tell it, because I cleaned it thoroughly and checked it up close up against a light. The perimeter seal of it, was good too. But anyways, here's pic of the new diaphragm.
Old one for immediate reference. (Without hardware attached to it)
Also from what I have gathered, there are name brand diaphragms and generics which tend to run cheaper prices. I figure the generics are made from cheaper materials which "wear out" sooner. My vaporizer and mixer setup is not an IMPCO, which I presume is a solid brand, so the old diaphragm was generic because the vaporizer and the mixer themselves are both generic. I guess it's just another backing fact of "you get what you pay for"
Glad to have all this documented for anyone else that may encounter propane problems, especially Buddy's posts. Thanks again, Buddy!
TacomaJD said:Hollytree suckssssss compared to Hale Mtn, and most every other park. Lol. Hale is a badass yota crawler park.
TacomaJD said:Also see this post quote below. I wouldn't be surpsised if you got a diaphragm from buddy, that you get it in time to put it in, and go ride Saturday if that fixes your problem.
TacomaJD said:LOL You didn't call Buddy first?! Shame on you....
If the same guy still owns Hollytree, that's the only way new trails are gonna be cut. He damn sure ain't gonna do anything there to better the place. We went through the same thing there a few years ago. I won't be back there. Piss poor business management.
Dwill817 said:It's gonna get better.. Me and a couple buddies have made good friends with the land owner and he's gonna let us cut and name a bunch of trails. One friend have already put a camper up there and another is about to.. It's not huge but there's some potential for some good crawlin trails. Not much hill killin though.. We found a couple ledges that are gonna make a hard hard trail, plus there's a bad ass creek bed trail on the other side of the mountain that I don't think many know about..
Dwill817 said:This is a good trail at Holleytree.. Just needs a better exit and entrance cut.. Kinda have to run through the woods!
http://youtu.be/-3-E1C_gLAA
rednecklights said:That's on the opposite side of the road as the check in, right ?
Dwill817 said:I'm really dying to come to Hale Mtn.. Huntsville has a lot of rocks and if it's anything like Hollytree, but bigger, it'll be fun!
I'll make it up there soon. I'm almost ready to ride..
Gonna order a set of RCVs in the next couple weeks..
paradisepwoffrd said:Which mixer are you using?
Sent from my SM-N920V using Tapatalk
