PORTER
I already have stickys, so no need to make wheeling any easier. Water/shot/etc is for comps.:flipoff:
5 gallons of water per tire is only 166 pounds.Roccrawler said:You still have to move the weight..
cisco said:If I get your drift, you will be moving the can through the water and not moving the water.
ToyBug said:Arguing.....internet.....retarded.
:flipoff:
Jaydog said:5 gallons of water per tire is only 166 pounds.
5 gallons of calcium chloride and water per tire is 220 lbs.
Either way it doesn't seem to be a whole lot of weight to move, Would that little amount of weight add a lot of stress to a 44 or a 60 for that matter?
Binder said:Yes that weight is a huge difference. That's the point of putting it in there.
Jaydog said:I just don't see it causing a lot more stress on axle shafts.
Jobless said:It increasing rotating weight being loaded on the axle bearing and ultimately the shaft/U-joint.
How can it not be more stressful on the axle shaft?
Roccrawler said:OK then pick up a empty tire, now pick up a water filled tire... Was it harder on your back?
Jaydog said:So if my spotter is 200lbs and riding shotgun then I should upgrade to Dana 60's?
Sorry Gibby, guess you need to get on a Treadmill. :kissmyass:Roccrawler said:OOOh Duh !!!!!! thats obvious
crash said:How so? The weight is on the ground and stays on the ground because its fluid ..
