Before you get too far into it you may want to see if the TPS is working correctly. With the volt meter hooked up work the throttle by hand (key on engine off) slowly and watch the voltage. It should move steadily in progression without any jumps up or down. You're looking for dead spots where the voltage has a dead spot or spike....Could be bad at idle.
too late i had already ****ed with that screw....
so yes i have a gauge on the fuel rail test fitting the entire time for troubleshooting, steady 60 psi. i now have a vacuum gauge also. vacuum runs steady during startup 17In for the thirty seconds then jumps down with the loping to like ten and moves up and down.
so i dont have the EGR wired into the system but the EGR is still bolted in place. im assuming the valve just stays closed. do i need to do something there?
