Binder
so i got a scan tool that does OBD II and will also do OBD I....i ran the scan and i think i found my problem, my map senser has three wires to it purple - ltgreen - grey.
it shows 4.99V at idle and should show very little at idle and 4.99 at WOT.
i look at all the diagrams and the wires should be
ltgreen - purple - grey....purple wire should be in the middle i believe the reference voltage and enable voltage wires are swapped at the connecter.
ill call the wiring place again tomorrow they have been very helpful on the phone.
Sounds like you're on to something.
It should show 5 volts with the engine off which would be about the same as WOT. Like you said, at idle/ high vacuum the volts should be very low.....
