patooyee
- Joined
- Sep 27, 2008
- Messages
- 5,692
I'm expecting a delivery of 2 FJ60 front axles for a future project any day now. I've been scouring the internet for info and finding that is is very scattered / not centralized. IE, there is no Toyota axle bible like there is a d60. I was hoping someone might fill me in / bring me up to snuff.
For instance, people have said I should put FJ80 balls on these axles so that I can run the bigger joint. But I plan to run RCV's or equivalents and every break I have seen of Longfields has been the shaft, not the joint. And 80 shafts are the same dia. as 60. So what's the point of having a stronger joint if the shaft is still the weak point? Or am I wrong about this generalization? Especially considering that aftermarket FJ80 knuckles from Hellfire are $1000/pair vs. Six Shooter FJ60 knuckles at $300/pr. And FJ80 donor housings to get balls off of are few and far between and expensive.
I understand that Longfield is now owned by Trail Gear? But RCV was the ones making Longfields all along? And now you can buy from RCV but Trail Gear is revamping the design or something? What is the end result of all that drama?
Do people plate stock knuckles on Toyotas like some people do with D60's? Are 80 knuckles as prone to failure as the 40/60/mini knuckles are?
Got any other info I should know?
