Southern X-Posure - 85 Toyota Truggy
Have you thought about Full hydro? Full hydro is so much easier and worth every penny you pay. Mine isn't streetin, but it doesn't do bad at higher speeds.
I have and its on a list....
Got the front end finished up and did some wheeling with RCPFA
Coming along nicely, just need to extend the drives shaft, bleed the brakes and replace some leaf spring bushings
Loaded the truck and the wife Sammy up and going to give it a good shakedown run today.
If you look close can see the exact spot I ran out of talant... :laughing:
Ran out of talent here too... Also blew a ex manifold gasket
https://www.youtube.com/watch?v=sI5VBTii-FE
Not sure if you figured out your SP problem but I had the same thing happening and it turned out when I drilled and tapped the box I didn't get all the metal shaving out, the pump ended up getting trash in the plunger and ****ing it up, I did everything I could to try and make it work but ended up sending it to PSC and they rebuilt it, but try and pull the plunger out and inspect it, you might have better luck than me
