The kush-j7 build by 417chevy
X2 on the xj coils...I run them in the rear...very flexy. I run progressive coils up front. Make sure to run long travel shocks with them otherwise it will be bouncy as hell. It's a cheap old school setup but it works :****:
"cheap old school setup"...you cant say that about your rig when its got an axle loaded with ouverson goodies :flipoff1: Nice flex by the way. I'll be happy if I can make it to the top of the bogger without rolling over
Just noticed a problem how would I go about fixing this I don't want to flip my hubs back out what do I do?
I always set them up flipped out, and weld my centers in the center of the wheel. Outside of tires with 44's will be around 96". That does two things, the problem your seeing now and puts the weighted pressure in the center of the tire which will make the tire work better. As tall as your jeep is I would want it wider to be more stable
Built me some spacers brought it out a little ways goin to grind the edge smooth on spindles so that way if it does ended up rubbing a little it won't be total carnage to my sidewall I'll get some pics tonight also starting on dash tonight
Pics of said spacers?
Got fuel cell mocked up to run fuel line
Got some of the dash figured out
I think cause of how big the cell is and having top loaders that would cause a problem
417chevy said:
What everyone's thoughts on inning fuel lines In the tub
Why would you need to do that? Just curious why you are even considering it.
Less likely hood of it being smashed or ripped I know I can run it on the frame rail but simple as it is to just run along the edge of the tub tucked in the lip just got me thinking about it
