I am in the process of planning the next build
I am running 5.13s now in a hi pinion 60, I will probably rob that axle from the Toyota for the new one ( it is as built as you can get a D60 with the exception of brass kingpin bushings and inner Cs. I have a 4.3 Atlas for the new one.
What I am having a hard time deciding is whether or not to stick with what I have and try it out or go ahead and re-gear the 60 down to say a 4.56....orrr swap the 4.3 atlas out for a 3.0 or something like that. I realize the pinion isn't as big/strong in the 5.13s. Also, the rear 60 will be staying in the Toyota so I would only have to re-gear one axle instead of two. The new build will be getting a 14bolt and I know 4.56 are easily found in those.
the new one will be a tube chassis, on 42in treps, auto, mildly built LS (in the 400hp range)
Toyota will be getting another D60 (probably less built) for the front
Thoughts?
and with that being said, I am looking for a 14b for the new one and a replacement 60 for the yota
Thanks
