crash2
-Oh no I picked a side-
Also--Do you have to purge the lines for the propane?
No need to purge on my system. The system I use is a little different that most. When you put power to the regulator it lets a shot of propane into the mixer, but since it is not reading anything from the wire that goes to the negitive on the distributor, it does not keep flowing. When the distributor is turning the negetive wire tells that little box to flow the propane.
It can get to much propane if you keep turning the power on and off. That will let the shot of propane in everytime power is turned on.
Just open the tank, turn power on, wait 10 seconds , then crank it over. When the engine is warm no need to wait the 10 second.
Seems odd that you can flood a pane system, but when it's cold and you keep turning it on and off will so propane rich that it wont start. I just open the throttle plate and blast shop air into the intake, then it fires off.
Now, you will have to bleed the coolant lines if the coolant has been drained, but unless you have drained the coolant your good to go.
The regulator will turn into one big ice cube if coolant in not getting to the regulator. If that be the case just bleed through one of the coolant lines.
When you start it make sure the exhaust wont melt lines like I did.
Crash, if you get a minute, whats his outside to outside tire measurement. That thing looks wide. Guessing 88" or so.
Thanks.
Robin, we still on for our King Of the Rocks race???![]()
:flipoff:
Better stick with the 42's![]()
either way, let me know when your maiden voyage to the rocks is. Wait any long, we could do some good snow wheeling........![]()
Wow--I pulled 6 feet out of the front hydro lines :haha:
Who's feet were they?.......WOW there are three people crawling around with no feet or are they even matched pairs?......Human feet?.....:haha: :flipoff:
Are you absolutly convinced that the new lines will handle it flexed out without a anti-sway bar(they tend to break)...........I never question your work, but this has me a bit concerned.
