crash2
-Oh no I picked a side-
skrause said:Big and heavy. :redneck: 4kw IIRC, came with the house.
Big fawker---yaaaaaaaa
I wouldn't worry about it shane--I think we got that stuf covered...:;
:wtf:crash said:I wouldn't worry about it shane--I think we got that stuf covered...:;
crash said:9)I will be bringing my generator but would like at least 2 more
crash said:Ok---here is how you get to the wall trail.
So head torwards reiter to where the first staging area is. Instead of turning into there keep going down the paved road (around 2 miles). Follow it up and up. You will come to a 120 RH corner, go around and up. After a bit you will come to a 90 degee RH corner (if you miss the corner you will run into a bunch of boulders where the pond area is blocked off). Go around the corner then the road makes a sweping LH turn. After the sweeping turn you will see a gravel road on your left. Turn there.
Its around 2-2.5 miles up the gravel raod to the trail head.
So follow the road up not making any turns (quite obviouse what the main line is). You will go under the power lines--soon after pass by a rock pit on your right--keep going. Follow it up till you come to a Y thats quite large/wide (just prior there is a large rock to your right--also known as the lil lions back).
At that Y turn right and head down the road. You will come to another Y (straight is the entrance to the wall trail). Right there is where we will be setting up camp...
If anybody needs directions on how to get to reiter just say so :;
Hip said:i have the tools in my truck.
large compressor, roto hammerdrill. air chisel gun. and something else in a box i didnt open. the compressor will not fit into my jeep so we will need an open bed to get it to the job site.
it would fit in the back of the jeep without the cage in the way but i dont think the openings between bars is large enough to slide it in.
GRNTACO said:I have a 3/8 and 1/2 drill. What size bits are you thinking?
crash said:Also--anybody have a drill with a small selection of bits?
TB-F said:I have a selection of high-powerd rifles. :flipoff: :haha:
crash said:I want the holes in the right spot--not 2 feet in either direction--seen you shoot before :flipoff:
crash said:3/8 should be fine ben...
Ya, one 2' wide ragged hole probably isn't what they want huh. :flipoff:GRNTACO said:If you think he is bad you should see Shane shoot........:haha:
Wildman said:Crash,
Well so much for my plans to leave here early tomorrow. The ex was suppose to take Karrlie today and now she isn't going to until tomorrow night at 1730. So I should get out of here around 1800 & be over there around 2000-2100.
Rick
War-Jeeper said:So yer gonna be there tomorow night and saturday night then?
Wildman said:Yes. My plan had been to leave over here in the daylight and be able to relax some. Just am not too happy about having to drag the Jeep over there in the dark.
crash said:Don't blame ya rick........
