Hellbilly
It works great for loading on the trailer :redneck:
And you ever wheeled out of state?
Next year (09) will be my year for out of state wheeling! :redneck:
You wheeled the outlet mall yet?:fawkdancesmiley:
Na---- Have you :redneck:
4:1 in toy reduction box and I have the HD output on the dana 300(stock gears). I havent upgraded the front output--been waiting to break that first. But ya--I have a 4.3
If you are going to run a 300 behind a toy reduction box, I'd put the really low gears in the toy box. Sarg's old drive train was set up this way and mine was the other. His worked alot better. I'ts alot easier to go low high with one stick in the toy box rather than 2 on the 300. Basicaly switch low and high in the toy box and leave the 300 in low all the time. That way you can get a front dig with one lever.
and 4to1's for a toy case is cheaper
ok so i have a 23 spline 4.7 gear set and a 2.28 23spline gear set, so i can go either way and it isn't going to cost me so 4.7 it is. what kind of final gear ratio will i see if i keep the gears in the 300 stock? sarg what did you upgrade in your 300?
Joe has got me thinking about running an auto i have always had a manual but i can see how an auto would be nice at time.... what are you guys opinions on this? thanks for the info!:beer:
You should come over and take a look at my buggy, ill help you figure out what you should run james. :flipoff:
my setup was 22re to a toy 5speed to a toy t-case w/4to1's then to a stock dana 300. This setup worked extremely well I never upgraded the d300 and I beat the piss out of it.:redneck:
