What module for my dodge?
Put on a Edge comp box and tap the pump, then you will have adjustable power up to a moderate amount of HP on the high setting. Then buy injectors if you think you need more (most of us always do). I can get you a good deal on one shoot me a pm. if you want.:beer:
Agreed, more power will always produce more heat, but if you compare the way injectors make power as compared to the way comp boxes do there's a huge difference.
I noticed no increase in EGT's or smoke with the small injectors I had installed. Installing huge injectors may not produce the same results.
you have to keep a balance between air and fuel. if you through to much fuel to anything it is going to get hot. you have to use moderation.
Thanks berne but I don't wanna run somebody elses parts---I will buy em first :awesomework: ...
totally understand.....but injectors are expensive (good ones anyways)
I got these for next to free, am totally/completely willing to loan/give them to you to run.....see if they are what you are looking for...
the DD2's should be good for about 80-90hp on a non-HO truck (like yours). so...they should be close power wise to what a Mach 1.2-1.6 would be, but w/ more smoke and more heat, prolly a little less milage, but for free to test out, and if you wanna keep them, fling me a quarter of what new Mach injectors cost and well be square.
I got them in a package deal when I bought my edge comp box....guy refused to split things up....but basically gave them to me....trust me, you won't be putting me out AT ALL...you know me Mikey...
I've just never installed them, cuz I know my clutch won't hold them w/ the box on......and know myself enough to know that I can't trust myself not to set the box to kill w/ them installed...
just puttin' it out there...
Anybody know if the only difference between the manual/auto is the turbo--injectors the same?
In any case I just wanna try and do it right...
other than the difference between the HO vs non-HO, aside from the turbo's, the injector pumps and injectors are the same AFAIK....
the HO's have different pumps and smaller injectors, which is why they tend to make a little more HP from injectors than the non-HO motors, but less HP than the non-HO motors from electro-boxes...
--B
Berne, an HO truck will never make as much hp as an SO pump if you're going for hp...
ya, when you start to really push things power wise....
but 90 horse injectors in a SO will make more hp in an HO truck...
this is getting off Mike's topic though..
I had all 6 replaced out at 19,000 miles. I hope i am an exception to the rule.:;
